Finishing up piecing a kit together.
NX 20118-10 kit: Mostly there, missing a few small things that I am getting from Garrett on Friday (Was missing nozzle bung, 150 jets, bolt kit). This kit has the lightning solenoids, WOT switch, shark nozzle. Bottle needs recert.
Racetronix pump & hotwire kit
HSW Microedge
I already have a pressure gauge & bottle heater. I am leaning towards mounting the bottle in the spare tire well.
Current engine mods on the car: AI LS6 heads, 235/242 111+3 cam, 1 7/8 Kooks headers with 3" x-pipe dumped, Fast 92, 92mm TB. 36lb FAST injectors 10.8:1 compression
Looking for opinions on what accessories I should pick up, planning on getting a purge, and a blowdown tube. Curious as to what spark plugs to switch to as well. (150 shot is the plan). Anything else I should take a look at?
HSW Microedge
I would recommend you using the NGK BR7EF's for plugs as well.
Trey
