tech gurus...
Old May 18, 2004 | 09:39 PM
joshs_ws6's Avatar
Default tech gurus...
How hard is it to install a msd window switch. I got the one for the ls1 off of tbryne. any links for directions or help would be greatly appriciated. also if you could email it to me at fud4less@hotmail.com i would greatly appriciate it. thank you
Old May 18, 2004 | 10:32 PM
Silly02SS's Avatar
it is really easy i installed mine in about 30 minutes without any experience, just cut the two loops for the 4cly application, this is required for ls1's, then put black wire to a ground, red wire to 12volt, white wire to the tach wire, which is the #10 wire its also white, and hook the yellow wire to the ground wire of your relay, or if you have a fuel pressure safety switch the yellow wire goes to it, hope that helps
