Changing to a dry kit few questions
Old Jul 7, 2014 | 02:43 PM
scantone1's Avatar
Default Changing to a dry kit few questions
I am in the process of swapping in a Holley Dominator and changing over to E85. I have a direct port kit now from IS and am running 6psi from the stand alone and a .30jet on the fuel side with a .40 on the nitrous side. Tune up is pretty good plugs always look good. Does anyone know how to figure out my pph of fuel I will need to add to the nitrous fuel map? I know every setup is a little different but I was wondering with the info given if there is a way to get in the ball park.
Old Jul 15, 2014 | 11:08 AM
brandon@nitrousoutlet's Avatar
You're going to have to get with whoever flowed that system and determine what it moved PPH wise per HP setting. From there you can calculate how much fuel you will need.
