My GTO is finally in the 10's...!
Made 3 motor passes and 7 nitrous passes. Each time getting a little quicker.
17.5 to 18 psi in the tires. 15 psi in the bags. After reviewing the videos I think I actually need more psi in the bags. Anyway, first run out ran a 11.9 on motor. Best motor run was my third one. Here is the slip.
Super pumped with how she is doing on motor.
Then onto the nawz. Out of my 7 nitrous passes 5 were 131.x traps. Each time I was getting a little quicker. Then this happens.
https://www.youtube.com/watch?v=Qwk8...ature=youtu.be
And it is always good to end on a high note...I was basically out of gas and out of bottle. She was running a little rich still even though I was actually fine tuning the jets this time out. high 10's at the top of 4th cause pressure drop.
I still feel the 60ft has more improvement but it is obvious the drag bags helped tons. I am no longer scraping exhaust onto ground.
5 years to do it but I finally met my goal.
Thanks.
Basically yes. I do have headers which shaved some weight over the stock manifolds. I have a lightweight skid plate and have removed the fuel tank brace and the rear tow hitch mount. I have added a 15lb bottle in the trunk so that kind of offsets things.
I have been meaning to get it on a scale sometime.
