heads and cam formula with spray 1998 formula with 91,000 miles 227 prc heads with a ms3 cam on a 113 lsa. Plan is to make around 600 on a 100 shot would this be taking a risk on the motor with 91,000 miles. |
600 on motor or at the wheels? |
100 shot? Keep the tune safe, run good oil, pull 4 degrees, install BR6ef plugs and let it eat |
Originally Posted by HCI2000SS
(Post 18351193)
Originally Posted by high impact
(Post 18351195)
You won't hit 600 rwhp on a 100 shot with that setup |
(Post 18351344)
What he said ^^^^ You most likely aren't going to get to 600 with that set up. 550 if everything is optimized. 600 is easily achievable with a little bigger shot. |
Yes 530-540 is more like it |
You can always shoot for as much HP and TQ you can get NA, and then add whatever shot you need to reach your goal. Just start small and work your way up and make sure you keep things safe by reading your plugs and making sure you have enough timing pulled. |
Just follow the guidelines and your motor will be fine. I imagine the car might net right around 500 with that combo, but the 100 shot will still pick the car up alot. Let me know if you have any questions man. -Garrett |
OP I used to get caught up in wanting certain dyno numbers too, but have learned the hard way that's it's not a good thing to get caught up in ;) As long as everything is done right and in good working order your car will make whatever it makes on any given dyno. Taking it to the track and racing others is the only true way to see how powerful your car truly is |
(Post 18351878)
(Post 18351878)
© 2024 MH Sub I, LLC dba Internet Brands
