NGK BR7EF or BR8EF
Old Aug 6, 2014 | 04:43 PM
N2Ojunky's Avatar
Question NGK BR7EF or BR8EF
My 98 LS1 Camaro "I was told" was tuned for a 175 shot. When I bought it it had motor plugs in it I will probably only spray a 150... "But knowing me I will probably go bigger at least the 175" Lol which plugs should I run? How will they act on motor and what should I gap at? Thanks
Old Aug 6, 2014 | 04:50 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Normally you want to go 1 step cooler per 100hp. I would put 7's in it and roll with it. Gap at .030 to .032.
-Garrett
Old Aug 6, 2014 | 05:04 PM
HCI2000SS's Avatar
I run BR7's and they work just as good as any other plug on motor. It's all in the tune
Old Aug 6, 2014 | 11:04 PM
GiggleJuiced_SS's Avatar
br7's here. was running a 150 shot for years. going up to a 200 now.
Old Aug 7, 2014 | 12:37 PM
Killer5.3's Avatar
Our car runs fine on a #10 plug. Sbe, 10:1 compression. Like said, a good tuner can get it to idle cruise fine on a colder plug. Our runs fine on a motor pass up to a Br8 ,but, anything colder will break up some above 6000 rpm. It will idle and cruise fine though on a 9 or 10. Sounds like a 7 is what you need for that jet though.
Old Aug 7, 2014 | 06:40 PM
speedtigger's Avatar
Old School Heavy
I have a couple boxes of B8EF in the garage, but I have never used them. Even with a 81N jet tune, my BR7s look perfect with no signs of excess heat. This is in a 10.8:1 LQ9.
Old Aug 7, 2014 | 07:13 PM
N2Ojunky's Avatar
What kind of gas are y'all running?
Old Aug 7, 2014 | 08:01 PM
Old School Heavy
Gettin' it done on 93 for me. Pulling 8 degrees and keeping the tune lean and clean.
Old Aug 7, 2014 | 08:02 PM
HCI2000SS's Avatar
Yep 93 for me as well
Old Aug 8, 2014 | 02:51 PM
93 octane only here. no race gas.
Old Aug 8, 2014 | 02:56 PM
N2Ojunky's Avatar
I went with BR7EF gapped at 30-32 and I will also be on 93 pump. Does ethanol gas affect performance?
