Nitrous fuel pump help
Old Aug 11, 2014 | 04:56 PM
Macdiesel's Avatar
Default Nitrous fuel pump help
Im asking this question as there appears to be some discrepency between vendors and manufacturers HP pump capabilities. My car is an 02 firehawk, full 3" exhaust, MS3 cam, lifters, stock intake/ heads/fuel injectors, etc. Car has 50k miles, and is 405hp/391 tq at the wheel. I am wanting to throw a 125 wet shot via plate kit on it and I am wondering what pump any of you guys recommend or are currently using as I am ignorant when it comes to fuel systems and Nitrous. any help is much appreciated, and from what I have read on here and been told most are split when it comes the hot wire upgrade and pump kit/brand. I am not brand loyal and just want to avoid a lean burn situation
Old Aug 11, 2014 | 05:27 PM
HCI2000SS's Avatar
I'd go with a Racetronix 255 pump with hotwire kit
Old Aug 13, 2014 | 06:16 AM
00FirebirdaREV's Avatar
Racetronix 255. Easy install. (Trap door)
Old Aug 13, 2014 | 08:38 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
This. IF you have anymore questions OP just let us know!
-Garrett
Old Aug 13, 2014 | 01:44 PM
4WOFURY's Avatar
Another for Racetronix kit. It uses a Walbro 255 pump, but they put it in a kit that makes it a dirt simple swap.
Hotwire kit is strongly recommended as the wiring in your car is 13+ years old, and has built some resistance.
