stand alone system
What all do I need to know about using a stand alone fuel system? I just purchased one, it is a 1 gallon fuel cell with holley low flow pump and regulator.
Thanks
Thanks
It allows you to run leaded high octane fuel in the stand alone and not worry about mixing fuel when you are planning on spraying. It allows a much safer system as you are not relying on your normal pump octane fuel and your fuel rail supply.
