300 shot questions
Will a nx gemini maf kit cause un even distribution of n02 and fuel throughout the cylinders, is this too big to pull fuel from stock fuel rails with stock regulator and fuel lines. is direct port a must for this big of a shot. will a progressor help against initial lean spike. all feed back is welcomed
Ls1tech & Truck Sponsor
Stock fuel pump too? If you are worried about distribution a direct port will help with that at higher horsepower settings, because you get the ability to tune each cylinder, so at least when you recognize one cylinder is running leaner, you can add some more fuel to that cylinder specifically, so it is safer from that standpoint. You really need a seperate regulator or standalone system if you are going to spray 300, and the fuel pump needs to be able to support what you are trying to spray.
Do you have a picture of the MAF plate? Either way, neither of the MAF plates went up to 300.
-Garrett
-Garrett
fuel system will be up too par. its the dual stage maf kit so I can run 4 solenoids on it. my main concern is will getting the fuel from the fuel rail be a problem. and is 300 shot to much for the maf kit if dual staged.
Also garrett, do you guys sell just the intake part of the direct port kit. like solenoids and the stuff that goes inside the intake I have feed line bottle and that stuff.
Yes we have plumb kits for a direct port. I wouldn't try to pull 300 from the rail, that could almost drain the rail. I would run a seperate regulator and y block in the main fuel supply line. The dual stage MAF plate will do 250hp on each side, you could spray 300 out of it, but I would be more comfortable having a direct port if I was going to spray 300 on the regular.
http://www.nitrousexpress.com/13385-...-hardware.html
I can give you forum pricing on this through PM or over the phone.
-Garrett
-Garrett
