175-200 shot on a 5.3 LS4?
Old Nov 30, 2014 | 05:22 AM
noobc6owner's Avatar
Default 175-200 shot on a 5.3 LS4?
Is this doable without any issues? Also what kind of et gains should I expect? Car is a Granprix fwd on m/t street radials 2
Old Nov 30, 2014 | 08:14 PM
Default Nitrous
Anybody have any info for me?
Old Dec 1, 2014 | 10:13 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
One of our employees has been spraying 200-250hp on a factory 5.3 with a cam for awhile now, with no issues. Lots of people on this forum have done 200+ also. Keep your tuneup safe, and it should live for awhile that way, you are dealing with a factory motor though, so keep that in mind if you are worried about hurting anything.
-Garrett
Old Dec 1, 2014 | 04:02 PM
FEAR LS's Avatar
Originally Posted by noobc6owner
Is this doable without any issues? Also what kind of et gains should I expect? Car is a Granprix fwd on m/t street radicals 2
1. Is this possible without any issues... NO, spraying that much on a stock engine is more than recommended. 150 is more of a "recommended" shot. Would I spray 200 on it? Yes. You need to be accepting of the fact it could go wrong.
2.What ET's do you run now? Obviously the slower you are naturally aspirated, the more you will pick up when on nitrous.
Tune Up: Colder plugs, Pull timing, Solid ANR.. Make sure you have the fuel capabilities to support that much nitrous as well.
Old Dec 1, 2014 | 07:57 PM
Cajun ELESS-ONE's Avatar
good luck with the trans holding up.
