cam/nitrous
Old Dec 23, 2014 | 08:07 PM
x275radial's Avatar
Default cam/nitrous
sup guys. my buddy has a 2001 5.3 with 40k on it. the motor has ls6 cam and a good valve train with ls6 head gaskets. my question, is the ls6 cam a good cam to spray with and hes doing this on pump gas how much could he spray a stock motor. also what timing would you run when the nitrous is all in he doesn't have a stepped retard box just goes straight to whatever timing we set it at when nitrous is activated.
thanks
Old Dec 24, 2014 | 08:48 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
How much are you looking to spray?
-Garrett
Old Dec 24, 2014 | 06:41 PM
x275radial's Avatar
150 shot
Old Dec 24, 2014 | 07:09 PM
WE TODD DID's Avatar
thanks
To answer your question, yes you can spray it with that cam. But you're doing yourself an injustice and would be much happier with a grind in the .60x/22x area. Check out the classifieds as I'm sure there are several floating around for a good price. You don't need a nitrous cam for that little amount that you plan on spraying.
Old Dec 24, 2014 | 09:49 PM
x275radial's Avatar
Thanks for your help.
