115k LS2 150shot safe?
Old Jan 8, 2015 | 10:39 PM
ViceCityPerformance's Avatar
Default 115k LS2 150shot safe?
Looking at doing a direct port 150 shot on an higher mileage ls2 (115,000 on the odo). The shortblock seems healthy still. Oil psi is on point. Stock cam. Might send the heads to be rebuilt with stiffer springs, lighter trunion assembly, coated lightweight titanium valves and milled down a bit; To better cope with the nitrous. I just want to know if it is safe with a proper tune to run a shot this big
Old Jan 9, 2015 | 12:19 AM
dicky98z's Avatar
You should go have a problem with 150. If I was you I'd look at a plate kit before doing direct port. The plate will be a lot cheaper and can handle more than 150 easily.
Old Jan 9, 2015 | 09:25 AM
brandon@nitrousoutlet's Avatar
Yes sir you should be fine with a 150. As you said, you will want the tune up to be pretty spot on. Let me know if I can be of any assistance!
Old Jan 9, 2015 | 10:01 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Like everyone else said you will be fine just make sure you use a cold enough spark plug and have a good tune on the car.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 14, 2015 | 08:49 AM
custm2500's Avatar
Ph.D. in HUBRIS
I would read and ask more questions before you go spraying. Yes an LS with vitually any millage is safe with a 150 shot, but anyone who has a direct port for a 150 shot has way too much money or not enough knowledge!
The only exception to that rule would be if you plan to spray 300 or more down shortly the road.
