What would you do???? Spring build!!
Old Jan 11, 2015 | 08:26 PM
M-Z28's Avatar
Default What would you do???? Spring build!!
Guys,
Never ran a nitrousing system, so I need some help deciding what to do. I have an 1998 LS1 6 speed 65,000 car that I'm planning on doing full bolt on's this spring (LT, ORY, LS6 Intake and true duals). I have future plans of a cam install next winter...
My brothers cammed Camaro is currently putting down 401 to the ground and would like to suprise him when I walk him with just bolt on's... LOL!!!
So I need help deciding what safe system to run.. To get that deer in the head lights look from him..
I'm thinking 125shot should get the job done.. What would you do and what system?
He's running 4.10 and I'm running stock 3.42 just as a side note.
Old Jan 12, 2015 | 06:03 AM
HCI2000SS's Avatar
With a 125 you should crush him! Make sure to run the proper plugs and tune and you'll be fine. All you need is a basic single nozzle wet kit for a small shot like that
Old Jan 12, 2015 | 04:22 PM
M-Z28's Avatar
Do you have a system you recommend and what type of plugs should I run? I guess the best time install is during the dyno tune for the bolt on's.
Do I need a programmer to change tune, when not spraying. . Sorry, but I don't know $hit about nitrous....
Old Jan 13, 2015 | 05:30 AM
HCI2000SS's Avatar
I run a NX single nozzle wet kit. I also run NGK BR7 plugs and a LNC-2000 to pull timing. Do you have the stock fuel pump right now?
Old Jan 13, 2015 | 11:01 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
This!
http://www.nitrousexpress.com/20421-...lb-bottle.html
This is an entry level single nozzle system. It will go up to 150 out of the box, and should be more than enough for what you need!
You can pull timing in HP tuners or buy the LNC-2000 as mentioned above. (It pulls timing when the nitrous system is armed.)
-Garrett
Old Jan 13, 2015 | 05:40 PM
M-Z28's Avatar
Yes,
Currently running new factory Acdelco fuel pump assembly...
