383 or SBE
Old Feb 16, 2015 | 11:23 AM
stherngent's Avatar
Default 383 or SBE
What are yalls thoughts? Wanting to go low 5's in the 1/8th. I already have a super vic and 4150 tb. Thanks
Old Feb 17, 2015 | 11:11 AM
stherngent's Avatar
maybe some more info? Thinking maybe going this way for budget, reuse 241's they are ported and polished (stock valves, thoughts on bigger valves?)
going to spray 300+ shot.
Old Feb 17, 2015 | 12:40 PM
Cold Zero's Avatar
300 shot is not easy ! .. even with 383ci it needs more efforts in tuning.
What is your plan for the nitrous setup ? plate or direct port ?
Do a head and cam. just my .02
Old Feb 17, 2015 | 12:46 PM
stherngent's Avatar
A head and cam want get me to low 5's
I have direct port and a plate.
Old Feb 17, 2015 | 01:16 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
There is plenty of people that have been in the low 6's and even 5's with a factory bottom end. Alot of it is in the tuneup, and the nitrous system itself (direct port will give you the best cylinder to cylinder distribution at higher horsepower levels), cam choice and things like that. That is really up to you, and really dependent on your budget and overall goals.
-Garrett
Old Feb 17, 2015 | 02:13 PM
stherngent's Avatar
ok i see a mistake I made. It should have read stock cube's, If I go this route I will do aftermarket rods and pistons with arp bolts and studs as needed.
