adjustable timing with nitrous?
Old Feb 19, 2015 | 09:44 AM
Sail Hatan's Avatar
Default adjustable timing with nitrous?
i just picked up a nitrous outlet plate kit, and i want to run a 150 shot on my car. from what i am reading i need some colder plugs, and to pull timing. whats the best way to pull timing for just when I'm using the nitrous, so that i don't have to be down on power all the time?
Old Feb 19, 2015 | 09:51 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
You can pull timing via HP tuners, or you can use an LNC-2000 timing controller from Lingenfelter. You wire it in and it pulls timing on the fly when you arm the nitrous system, that way you can still have an aggresive N/A tune.
http://www.lingenfelter.com/mm5/merc...3#.VOYJfC5yIyU
-Garrett
Old Feb 19, 2015 | 10:34 AM
HCI2000SS's Avatar
I run the LNC-2000 and love it.
Old Feb 19, 2015 | 10:58 AM
Sail Hatan's Avatar
thanks guys! thats exactly what i need.
Old Feb 19, 2015 | 11:50 AM
brandon@nitrousoutlet's Avatar
Th LNC-2000 is the way to go!
http://www.nitrousoutlet.com/electro...ontroller.html
