Daytona Sensor (Modotek) N20 controller help
Old Apr 1, 2015 | 12:41 PM
LIL SS's Avatar
Moderator
Default Daytona Sensor (Modotek) N20 controller help
I am hoping someone here is using either Daytona Sensor's or Modotek's N20 controller (same thing, just private label).
I am not able to see RPM with the N20 controller. Like my Autometer Tach, I am using PCM Red 10 to provide the controller my RPM feed. With out RPM, I won't be able to:
1) Use trans brake (Need the built in window switch to start the programs)
2) Control electric Shift noid (GPIO on controller grounds relay for 1-2 shift)
3) Use Window switch function for safety
I have tried fiddling around with Pulses per Rev and also the Debounce setting. If someone can enlighten me as to what worked for them, I would greatly appreciate it!
Shaun
