timing question
Old Jun 12, 2015 | 09:06 AM
jt_2002_ta's Avatar
Default timing question
I was wondering how much timing to pull on a 150 shot. Timing is currently at *27 and will be pulling the timing with a lnc2000. Has br7ef plugs. Thanks
Old Jun 12, 2015 | 09:16 AM
HCI2000SS's Avatar
I pulled 5 degrees on a 125 shot with mods in sig. My timing n/a is at 26
Old Jun 12, 2015 | 12:45 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
I would start with 4-5* like mentioned above.
Thanks,
Garrett
Old Jun 12, 2015 | 12:46 PM
jt_2002_ta's Avatar
Thanks,
Garrett
Pull 4-5* to start on a 150?? From the n/a 27* timing?
Old Jun 12, 2015 | 12:49 PM
No. 4-5* from where its making the most power N/A. Typically the rule is 2* per 50hp to start with. I thought I read you were spraying 125**. For 150hp I would pull at least 5 degrees.
Thanks,
Garrett
Old Jun 17, 2015 | 11:28 PM
ejbta2's Avatar
My tuner set mine to 22* for 150 shot on my setup. Plugs look great. mods in sig.
