To spray or not to spray?
Old Jul 15, 2015 | 03:05 PM
chrisLT1's Avatar
Default To spray or not to spray?
Have done a little searching and im seeing answers all over the place. SO don't murder me on here I don't know a hole lot about the juice
2002 stock motor LS LTs ORY pipe lid 3500 stall and pretty good high octane pump gas tune
1.all I want is to spray 100 shot would I need a retune to play safely?
2.should I spray before or after the MAF?
Old Jul 15, 2015 | 03:15 PM
HCI2000SS's Avatar
You running stock injectors and fuel pump?
Old Jul 15, 2015 | 03:17 PM
chrisLT1's Avatar
yes all stock
Old Jul 15, 2015 | 03:29 PM
HCI2000SS's Avatar
To do it "safe" you really should pull a little timing and run a better plug than stock. I have a friend that has a full bolt ons 2000 SS with a 125 shot, and he's doing fine with stock pump and injectors, but he's also running BR7 plugs and pulling 5 degrees on the nitrous
Old Jul 15, 2015 | 03:53 PM
chrisLT1's Avatar
kinda what I was thinking have had another guy tell me to pull it 2 degrees guess im not quite ready for the bottle
Old Jul 15, 2015 | 04:44 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
It would be better to get the car tuned on the nitrous so you can get the full potential out of the system. Also if it's a wet system you will spray after the maf.
-Chris
