Heads/cam 100-150 shot, what plug?
Ls1tech & Truck Sponsor
Yep. BR7EF plugs are fine for your application, as mentioned above. If it was alot higher compression I might drop down a heat range or so extra. Also, just so you know, for normal compression, (12.5:1 or lower) the general rule of thumb is 1 step cooler on the plug per 100hp of nitrous.
Thanks,
Garrett
Thanks,
Garrett
