E85 dry or wet setup
Old Aug 18, 2015 | 03:04 PM
BPlumCrazy-SS's Avatar
Default E85 dry or wet setup
I have a LS3 416 running on E85 and looking to add around a 300 shot direct port.
I believe I have the fuel system and injector to support the 300 dry shot.
what are the pros and cons between the two.
1 pro for the dry is I'm running a flex fuel sensor so my timing should auto correct itself if its not true E85 and the retard will pull from that. I will be using EFI live to tune with, am I thinking correctly on this.
also any tuners around the Houston area that are good with tuning nitrous on E-85 I hear its different than your normal race fuels
Old Aug 18, 2015 | 03:18 PM
brandon@nitrousoutlet's Avatar
Dry hands down. Why E85 though? Is it a street car? What pump and injectors are you running?
Old Aug 18, 2015 | 03:38 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Check out HP motorsports in Katy.
If you have the capability to tune for dry and the pump/injector to support it, it is great.
Otherwise I would stick with wet. Why not E85? You can get a tuneup just as consistent and run more timing than pump gas, not as "great" as race fuel, but alot cheaper in return. I'm assuming its a street strip car.
-Garrett
Old Aug 19, 2015 | 11:35 AM
Yes this is a street/strip car, I'm running E85 because my CR is around 12.5
As for Injectors I have ID1000's and a aero motive fuel pump. I put down around 550hp unlocked
Old Aug 19, 2015 | 11:58 AM
You should be good on injector. Can't say on the pump as you weren't very specific. You're planning on using the COS in EFI Live right?
Old Aug 20, 2015 | 07:57 AM
yes that is correct on the COS the pump is a aeromotive A1000 pump
Old Aug 20, 2015 | 10:41 AM
gtslo88's Avatar
One of the best EFI Live Tuners is D3 Performance Engineering. They are familiar with the exact setup you are talking about. Silver Z06 with a big motor/ Big dry shot all controlled through the EFI Live. I would give them a call.
