More nitrous , same et, less mph? !?!
If it was the converter it wouldn't lose 5mph even driving through it. Mid the race weight is the same it would just cross the stripe at more RPM.
Going from a 150 to a 300 is a big jump, I'd bet it's off on the tune up. Especially with having to reduce the fuel jetting so much....
Wa
But your issue is more than that. I don't think you're getting enough nitrous. Was the system flowed and blueprinted? I can't believe that -2 is enough to flow for a 099 jet. 1/8" tubing is 0.125"OD leaving less than 013 for wall thickness. You said you are running an 046 fuel jet when it calls for an 078..... thats almost 2.5 times less area of the jet....
Something with this is majorly off... be very careful because you're probably close to hurting the engine.
After re-reading about the jets he running I agree though I don't think it's the converter.
Went to the track today all on a 150 shot.
Car went 127mph at 10.4 1.4 60'
On motor it went 11.9 at 115.
Both passed were same tunes. Running 24* and about 12.3 afr
127mph to 130mph from 150 to 300.... something is wrong.
Not trying to be a dick, but you really need to take a good look over everything, twice or three times over... Ive burned up enough engines to know youre in the danger zone.
