Issue with NOS Mini 15974
Old Feb 20, 2016 | 04:52 PM
Dsmauney's Avatar
Default Same issue !!!
Hey guys I'm having the same issue !!! Any help would be greatly appreciated!! What was your solution iron Indian?
Old Feb 20, 2016 | 05:03 PM
03EBZ06's Avatar
Explain how your system is setup.
Old Feb 20, 2016 | 05:04 PM
Dsmauney's Avatar
im using white tach wire from cluster, grounds are separated and no other grounds are at the same point, have 12v+ arming switch coming straight from the battery, I am getting good tach reading and good tps reading but when I test the system stage one flashes identical to the OPs system..
Old Feb 20, 2016 | 05:09 PM
Dsmauney's Avatar
Ion have an 05 c6 corvette btw..
Old Feb 20, 2016 | 09:07 PM
03EBZ06's Avatar
go param by param on the handheld and list your settings. also, can you draw out your schematic?
I am very familiar w/this device, as several here are, but would be better if you draw out the whole setup so we can assess it.
Old Feb 21, 2016 | 03:32 PM
Dsmauney's Avatar
Default Issue fixed
So after many hours of trying to find the issue I have come to the conclusion it is the tps ! I removed tps and hooked up a micro switch and system works perfectly... Tps I use was from throttle body and showed 4.5 volts at wot... Is there any fix for this or am I going to have to stick with micro switch?
Old Feb 21, 2016 | 05:32 PM
03EBZ06's Avatar
micro switch is just something else to fail. Play w/the fly by wire TPS. I use the dark blue wire on my 2002. Also, go through the mini's learn procedure again for the TPS and see if you can get it to work.
Take your time. Your almost done!
