decided to go the spray route...questions??
Old Jun 9, 2004 | 01:11 AM
DeepBlueZ's Avatar
Default decided to go the spray route...questions??
ok, after having a friend do H/C and blow up 3 days later and another friend with a procharger crack a piston, i've decided to leave my motor alone internally and add some nitrous for a little boost in performance but i've got some questions since i've never actually used it.
1.) how much can i spray in reality??? 60K mile motor...please dont tell me i can get away with a 150 shot....i want to know how much i can spray semi-reliably for awhile...i was thinking of just going with 100 and leaving it at that....opinions???
2.) the stock fuel system (gotta love the 98 fuel system ) and ignition should be able to handle the spray correct??
3.) i'm pretty sure i want to go with a dry shot. id rather have low bottle pressure and lack a little power than deal with manifold backfires and such...opinions???
4.) i dont want to set the car up for nitrous, but rather i'd like to run it the way it is with just a little boost so i'm not looking to switch to a tight nitrous converter....can i spray the Vig 3200 without gearing or durability problems???
5) when i do install the kit, i'd like to go with the following stuff, window switch (i figure on at 3000ish rpm off at 5900 or so) w/ the obvious WOT switch (i dont want to be fumbling with a button), fuel pressure safety switch, bottle heater and purge....missing anything???
6) given traction (i have ET streets if necessary), i was estimating times in the 11.30-11.40 range on a 100 shot...does this sound about right??? ( i would think the car is capable of an 11.90 on motor with ET streets and the Vig)..
sorry for the long post, just trying to get a little info on the whole nitrous issue...thanx.
Old Jun 9, 2004 | 10:35 AM
Turo's Avatar
on a dry system, you would be fine with a 100 shot on your motor. for anything higher than 125 i would recommend a wet shot. as far as safety equipment, looks like you have everything covered. for ET, i know a 100 wet shot is good for about 1 second off your ET (with traction of course), so your estimation sounds pretty good (in fact you might be able to run faster than that). good luck!
Old Jun 9, 2004 | 01:52 PM
PewterZ's Avatar
Old Jun 9, 2004 | 03:31 PM
DeepBlueZ's Avatar
thanx
Old Jun 9, 2004 | 11:41 PM
DeepBlueZ's Avatar
TTT...can anyone give me an answer on the converter thing??? will i blow through a vig 3200?? (keep in mind it true stalls at 3800.)
