Residual fuel in intake, normal?
Got back to the shop and pulled the intake and noticed there was residual gasoline in the throttle body/air intake. Not a lot, but def there.
Is that normal for a wet shot?
It looks like you're using some of our solenoids on the setup. If you'd like to give me a shout here at the shop I can go over what it would take to get those rebuilt/checked. That away you can have a worry free setup.
-Chris
I assume the only reason the lines/noxxles dont empty them selves is because they should be tight to create a syphon.
Im wondering if one of my lines coming from the noid to the nozzle is not sealing right
