Converting Dry Kit to Wet Kit
Old Jan 20, 2016 | 06:02 PM
weems's Avatar
Default Converting Dry Kit to Wet Kit
When I bought my camaro the previous owner had installed a dual nozzle NOS dry kit. I want to spray the car but after much reading and suggestions from Mike @ RPM it looks like I am going to convert it to Nitrous. Is the conversion kit on Nitrous Outlet the only thing I need to convert it? Would I be better off just pulling the dry kit, selling it and buying a wet kit?
Nitrous newbie here, done a lot of research, but never had a n2o car.
Old Jan 21, 2016 | 08:57 AM
AJatNitrousOutlet's Avatar
Is it still using a NOS solenoid? And if so, do you know which one it is? Generally, our dry-to-wet conversion kit will work fine for you, but depending on what nitrous solenoid you already have it may affect jetting. The conversion kit will include everything necessary to turn a dry kit into a wet kit. It includes the fuel solenoid, necessary lines and fittings, a wet nozzle, and a standard fuel 'T'. For the LS though, I'd recommend getting one of our GM EFI Fuel Distribution Blocks. It's a fitting that goes on the fuel rail and will make getting your fuel much easier.
