would a progressive controller help keep a engine together
Old Feb 29, 2016 | 07:32 PM
Wesley Bostic's Avatar
Default would a progressive controller help keep a engine together
If a progressive nitrous controller can be set to one shot then ramp up over a set time wouldint this keep a engine together allot longer then hiting it with a single straight shot?
Old Mar 1, 2016 | 06:35 AM
jblankenship's Avatar
Progressing can be easier on the motor. But introducing the nitrous at a higher rpm will as well to reduce to the torque spike.
Old Mar 1, 2016 | 01:46 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
It has the potential to help since you can soften the initial hit.
-Chris
Old Mar 1, 2016 | 08:23 PM
-Chris
That's my thought exactly it would be fun to play around with a junkyard engine and over time up it till she goes then back off enough it will last or at least till I build a bottom end
Old Mar 1, 2016 | 08:24 PM
Thanks for the reply makes perfect sense
Old Mar 2, 2016 | 03:13 PM
brandon@nitrousoutlet's Avatar
A progressive can soften the hit and lower the initial strain on internals but a correct tune up in general is what keeps motors alive on nitrous. If you need any help, please feel free to contact us!
Old Mar 2, 2016 | 11:37 PM
Rudy72's Avatar
Timing is the double edge sword, it releases power potential, yet getting too greedy can cost you your engine, there is a fine line between advance of no return, just enough to be happy in ET, MPH & happy Motor!! Now get traction and make some power!!
