Calling Tierod
Use NGK TR6 spark plugs the same as the gen 3 do.
My Allison was completely stock nothing done to it. Start out with a 100hp shot to let the Alli adjust to the added power then work your way up and run it in tow mode.
I used a switch that I mounted on the shifter all I had to do was move my finger to the left to hit the button. A window switch is always a good idea set it just under stall speed max at 5300rpm and the rev limiter needs to be at 5500rpm.
I matted the gas and held the brake as soon as I let off the brake Id hit the nitrous and held it tell the end of the 1/4 mile. Because you've got a aggressive westers tune you need a way to pull timing out. Ramchager make a controller to pull timing. When you go to a 150hp or 200hp let the torsions down till the tie rods are level with the center Link or you'll wheel hop the front end and bend the tie rods. Most of all have fun!!!
