Pulling timing
Old Mar 31, 2016 | 07:47 PM
Cody5's Avatar
Default Pulling timing
Alright guys. I'm buying my plate kit tomorrow. I plan on running 100 shot max. No more. I am also purchasing a window switch. Do I need to pull timing? Stock 2005 ctsv.
Old Apr 1, 2016 | 07:27 AM
Bowtiedford's Avatar
rule of thumb is for every 50hp you pull 2 degrees of timing, A lot of guys don't pull timing till they reach the 125 to 150 mark. I ran 150 for years and never pulled timing and then my buddies car at 150 needed to pull 4 degrees to stop spark knock.
Old Apr 1, 2016 | 11:02 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
What he said...
-Chris
Old Apr 1, 2016 | 01:39 PM
Cody5's Avatar
how hard is it to hook up the window switch?
Old Apr 1, 2016 | 02:27 PM
It not hard at all. Tach and TPS will run to either the ECM or you go off the TPS sensor or a coil pack for the hookup.
-Chris
