nitrous plate and fast 102 intake ??
Old Apr 4, 2016 | 09:52 PM
M1SERY's Avatar
Default nitrous plate and fast 102 intake ??
Can i use my 92 mm nitrous plate, with my new fast 102, it looks like the line my not have room to screw in, thanks in advance
Old Apr 5, 2016 | 11:54 AM
brandon@nitrousoutlet's Avatar
Unfortunately, if you have our 92mm plate with the inlet fittings located toward the rear of the plate, it will not fit. There won't be enough room to put a line on the fitting. We recommend for our customers that have Fast 102mm intakes, to run the matching 102mm plate. If you have any questions, please don't hesitate to ask!
Old Apr 5, 2016 | 09:28 PM
Bowtiedford's Avatar
they know for sure, I have had all 4 combos. fast 92 Fast 102 and both plates. Fast 102 is taller I believe.
