Nitrous Outlet Plate Kit Questions
Old Apr 23, 2016 | 06:59 AM
aaronwatson89's Avatar
Default Nitrous Outlet Plate Kit Questions
Hey guys i recently purchased the nitrous outlet 102mm plate kit with braided lines instead of the hard lines. I have a few questions on the fuel supply for the fuel solenoid. I am running a lonnies twin in-tank setup with -8 supply to regulator and -6 return. My regulator is vacuum reference and dips down when accelerating, which from what i read is correct. My question, since the fuel pressure is dropping at the rails isnt this going to affect the fuel for my nitrous kit if i tap into the rail?
Old Apr 23, 2016 | 07:12 AM
Bowtiedford's Avatar
I think 150 shot and below you would be safe, the regulator will adjust. My only concern is that spike when you hit the nitrous on how fast the reg. can react. to supply the extra fuel. How much does your fuel dip down too?
Old Apr 23, 2016 | 07:31 AM
If i remember correctly it will dip down to low 50s.
Old Apr 23, 2016 | 08:57 PM
Ben.'s Avatar
Just jet it so it's safe for the whole run. It will be slightly ritcher at higher fuel pressures but it wont hurt anything. Just jet it so it's "right" when at your lowest fuel pressure.
