nitrous?
As far as the size shot goes, you'll probably be happy with the gains had from a 100 shot, but if you're feeling gutsy, it wouldn't hurt to up to a 150 shot. Anything above that and you're looking at octane higher than 93 and at least a 155lph fuel pump.
Another thing I would recommend is a Timing Tuner Box. It allows the user to keep a tune that's aggressive for 'motor' and then when the nitrous is sprayed, it pulls timing out. The user can decide how much timing to pull out, which will depend on the size shot you've decided to spray. The general rule is 2 degrees for every 50hp worth of nitrous.
The cost of the NX kit, Gen X-II, MSD Window Switch, and Timing Tuner box is generally close to $1,000. Check out www.nitrousoutlet.com for the best deals on NX products. Nitrousoutlet.com also has some top-notch customer service.
You'll also need new spark plugs. I recommend the NGK TR6's. You can pick those up at your local auto parts store.
Enjoy...
