Plugs for a 250 shot?
Old Jun 10, 2016 | 11:32 AM
94FBIRD's Avatar
Default Plugs for a 250 shot?
I've been running an NGK 6 for the 150 shot. I'm thinking a 7 or 8 for a 250. Using 104 in the tank and 112 in the stand-alone. I will pull 12 degrees of timing, also. Thanks!
Old Jun 10, 2016 | 12:15 PM
Nitro Dave's Nitrous Outlet's Avatar
What are the specs on the motor? Compression? This info will help me choose the correct plug for you.
Old Jun 10, 2016 | 03:28 PM
94FBIRD's Avatar
383 LT1 with a 12.48 CR, but I am at 5,000 feet, so a lot less cylinder pressure. It's in 3,850 pound( with driver) Formula A4.
Old Jun 10, 2016 | 04:52 PM
for a gasket seat plug you will need R5671A-8 and for a tapered seat you will need a B8efs -Matt
Old Jun 11, 2016 | 10:59 PM
94FBIRD's Avatar
THANKS! I'll use the B8efs then.
