Microedge issues please help
Old Oct 18, 2016 | 09:11 AM
GbodyNUT's Avatar
Default Microedge issues please help
So I bought a kit on here a while back with a microedge controller. I have everything hooked up and working. Only issues I am having is when it sprays it says lean and keeps flashing it but my wide band says 12.3/12.4. If it doesn't do that it wil.come on and pulse real bad like it's coming on and off really fast. I have looked through the forum and can't find much on it so if there is anyone out there that has some knowledge on this thing it would be awsome. I'm only trying a 50 shot right now to get it right.
Old Oct 18, 2016 | 02:57 PM
tug686spd's Avatar
Your lean cut off is probly shutting it down. It works the same as a rpm window switch. Go in and max out the lean and rich cut off tables while trying to test it. I'm also pretty sure you can just turn that off. If that dont help post back and I'll think of something else.
Old Oct 18, 2016 | 07:05 PM
GbodyNUT's Avatar
I'll give it a try and see what it does. I'll post back and let you know how it goes. Thanks for the help.
