Nitrous outlet bottle question
Old Nov 12, 2016 | 10:40 AM
OEF14vette's Avatar
Default Nitrous outlet bottle question
I have a nitrous outlet bottle and their bottle heater with pressure switch. My question is can I use the port labeled push port for my pressure switch so that I can use the gauge port for the gauge? I have a -6 manifold but would rather heat the bottle with the valve closed since I will be racing in 0 degree weather and will open the valve when I'm in staging lanes. Attached is a picture of the valve and port in question. Thanks in advance
Old Nov 14, 2016 | 11:37 AM
Nitro Dave's Nitrous Outlet's Avatar
Yes you can remove the 1/8th NPT plug and install the pressure switch, PN 00-60002 That plug will have blue loc-tite on it so you may have to heat up the plug to remove it. When installing the pressure switch you can also put a drop of blue loc-tite on it and tighten it up. Make sure the bottle is completely EMPTY before removing the plug. If not your nitrous will leak out. If you have any questions feel free to email me or call me directly 254-848-4300 EXT 109
