Nitrous filter fitting
Old Dec 9, 2016 | 02:18 PM
baronsmith98's Avatar
Default Nitrous filter fitting
I have a damaged fitting on my nitrous filter. They come with stainless steel fittings and I have an aluminum fitting that will work. Is it fine using an aluminum fitting at this pressure?
Old Dec 13, 2016 | 12:25 PM
PONTIAC SLP's Avatar
Yep .
Old Mar 13, 2019 | 05:50 PM
Forcedair's Avatar
I have the exact same problem. I have a brand new filter/regulator and it leaks at the outlet side. I have made sure the fitting is correct and have gone as far as buying a new Russel fitting. I starting to believe there is a problem with the filter seals or outlet.
Old Mar 15, 2019 | 08:41 AM
brandon@nitrousoutlet's Avatar
Are you using any type of sealant?
