T56 nitrous questions.
Old Mar 24, 2017 | 10:12 PM
VandykeT/A's Avatar
Default T56 nitrous questions.
I'm considering spraying my 408 M6 car. I've never used nitrous before but I'm curious as to how a few things will work. I understand the window switch wot switch etc but since I'm leaving off a 2 step (foot on the floor) how will that work if I'm injecting nitrous at wot. Do I need to wire something into the clutch or just be careful not to leave off the 2 step at complete wot. Also power shifting. How will that small window of time between shifts where the car isn't under load effect the engine. I only plan on a 150-200 shot to get the car into the 9s and I'm on stock head bolts. Will that be safe. Car is making 571/522 on motor. Thanks
Old Mar 25, 2017 | 07:11 AM
Jtm2085's Avatar
I am in the same predicament with the two step. But you can use a window switch and set it a few hundred rpm lower than when you will shift it. That way you can wot shift with out spraying
Old Mar 25, 2017 | 07:13 AM
Jtm2085's Avatar
Also, what set up are you running skin the 408. Those are great numbers!
Old Mar 25, 2017 | 06:18 PM
VandykeT/A's Avatar
FAST 102 ported, PRC 247 heads and a 251/259 cam. 4" exhaust, 4" intake tract. 93 octane.
Old Mar 25, 2017 | 08:19 PM
tug686spd's Avatar
If your using a signal wire from the clutch to activate you 2 step you can use the same wire to trigger a relay to interrupt the nitrous. You could interrupt wot, rpm, arming wires. Personally I'd go with rpm I think that way the system stays powered up and is just waiting for the trigger again. With wot input depending if its a rising or falling voltage system I think with falling it would keep spraying because it would be seeing 0v.
