Stand alone fuel system questions.
With a stand alone setup and running race gas or some sort of other fuel, I'll obviously have to tune for this correct? I'm currently tuned as I'm setup right now with 91 and I manually take away timing via LNC-2000. Is there another way around this? I really don't want to screw with loading 2 different tunes all the time. That's why I setup my car with the LNC-2000 in the first place, so I wouldn't need a N/A tune and a Nitrous tune. What are you guys doing to go around this hurdle?
The fuel for your motor will still come from the main tank, so you won't need to change anything in the ecu. The only tuning you will need to do is via the jets in your system(air/fuel) and the lnc-2000(spark). Let me know if you have any more questions!
Thanks,
