What's this part? 1 Attachment(s) I purchased a 2000 WS6 that had this on it. Don't know much about it other than it's an eye sore. I would imagine it's nitrous related and if i remove it can i just put a normal schrader valve cap back on like oem? Thanks for your help Attachment 584605 |
yep just cap it off, looks like some type of Hobbs switch that is pressure related to turn something off or on |
Awesome thank you for your help |
Fuel pressure safety switch. The schrader guts were probly removed so you'll have to replace them when capping it. |
Originally Posted by tug686spd
(Post 19639080)
Fuel pressure safety switch. The schrader guts were probly removed so you'll have to replace them when capping it. What is the purpose of this? Is it actually for nitrous because I was just taking a guess in the dark. Thank you for your help |
That is a great looking car in your profile picture. |
That switch is often used with nitrous kits so in case you lose fuel pressure it will cut power to the nitrous kit so you will not run lean |
It actually looks like your adapter is leaking/seeping a little on the switch side of the adapter fitting. I believe the schrader stem is the same size as tire/tube so you should be able to fing and get one really cheap then cap it. |
Originally Posted by RobsZ28
(Post 19639513)
Originally Posted by baronsmith98
(Post 19639514)
(Post 19639673)
Originally Posted by Docrocket1967
(Post 19639978)
It's not mine I just liked the color and was saved on the computer so i used it |
(Post 19640007)
It was mine, my favorite picture of the car. Cool to see someone else likes it too, and uses the picture. |
(Post 19641558)
That's awesome. Got a thread on here where I could see more pictures of it? https://ls1tech.com/forums/drag-raci...aro-build.html |
I will definitely check this out. Thank you. |
| All times are GMT -5. The time now is 02:45 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
