Installing a DP in a plastic intake.
Old Jun 30, 2004 | 10:31 PM
StupidFast's Avatar
Default Installing a DP in a plastic intake.
Can I just tap and thread the nozzles into the plastic truck intake? Will this work fine or do I need some adhessive. I really don't wan't to "glue" the nozzles in, I would like to be able to reuse them later. Any suggestions?
Thanks.
Old Jul 1, 2004 | 12:05 AM
Nitro Dave's Nitrous Outlet's Avatar
The problem is that these plastic intakes are not that thick.So you do not actually get that many threads into it.Use a medium grade locktite or apoxe.Its also easer using a pirahna nozzle.
Dave
Old Jul 1, 2004 | 08:56 AM
taqwache's Avatar
i have done it before. if you dont use any locktite, the nozzle will move around quite a bit but it can be done. there is several people here that have a DP like this.
