msd distributorless window switch problems
Old Jul 1, 2004 | 07:46 PM
jsm00z28ss's Avatar
Default msd distributorless window switch problems
I have an msd distributorless window switch for my 2000 Z28 SS. The problem I am running into is that while I have 3000(on) and 6000(off) pills. The switch is really going on at 1500 and off at 3000. I have no idea why it is being cut directly in half. Any help would be great because I have not run with my nitrous kit yet.
Old Jul 1, 2004 | 07:48 PM
slow's Avatar
did you cut the wires to put the window switch into 4 cylinder mode to support the LS1's coil per plug ignition system?
if not, cut the 2 loops, and you should be fine
Ryan.
Old Jul 2, 2004 | 04:14 PM
Cheatin' Chad's Avatar
Luck you tested this first eh? N20 on at 1500 could be a problem
I agree with SLOW on this one.
Old Jul 2, 2004 | 05:41 PM
Squintz Palladoris's Avatar
Yep Cut the loops.
Brad
Old Jul 3, 2004 | 03:47 PM
jsm00z28ss's Avatar
I have another window switch and it has the the blue wire but it did not work because a wire had come off one of the sockets where the pill sits in. The one that is on the car is msd part number 89561. It was the one that they recomended for me to use so I do not think there is a blue wire to cut. I was going to try putting a 6000(on) and a 12000(off) because if it cuts it in half then I should be ok. I just do not know where I can buy these pills.
Old Jul 3, 2004 | 05:21 PM
Turo's Avatar
does it have 2 loops coming out of the side? if so, those are the ones you need to cut, read the directions. i wouldn't do the 6000 on 12000 off (if you can even find those pills), i would try to do it right, you dont want to cut corners with nitrous
