Which window switch to get?
Old Mar 31, 2018 | 04:54 PM
curtisad's Avatar
Default Which window switch to get?
I currently have a window switch that is simply called "timing tuner". It doesn't work and was wondering if you guys could recommend a modern window switch that is a plug and play type. I need one that retards timing and shuts off the no2 at a specific rpm.
It comments/suggestions will be greatly appreciated.
Curtis
Old Mar 31, 2018 | 08:53 PM
black&blu's Avatar
Nitrous Outlet makes a good one. Lingerfelter and Nitrous Express also make some but I do not have any experience with those two. The nitrous outlet one works really well and is easy to program. You need the tach wire (white) and TPS (blue) from the PCM. If you need to pull timing you need the Lingerfelter one as it has an add on ignition component.
Old Mar 31, 2018 | 09:31 PM
HCI2000SS's Avatar
Why not just get the Timing Tuner fixed since it already has timing retard and window switch built into the unit
Old Apr 1, 2018 | 02:03 AM
allblackedout5's Avatar
I’d recommend a lingenfelter lnc2000 for your timing and nitrous express maximizer nitrous controller. My honest opinion for basic nitrous tuning and setup couldn’t be a better, easier to use, or easier to install combination... and the amount of features they offer at the low price point of each cant be beat.
Old Apr 1, 2018 | 09:06 AM
98redorangeta's Avatar
The timing tuner is the only one I know that does both in one box. That being said you can still replace it if you can’t get it fixed.
You can still buy a replacement here
http://www.ws6project.com/user_stor/...us-controller/
Or you can move to LNC 200 and a basic window switch this will give you the option of a 2 step or spark based rev limiter in addition to what your current unit has.
Window switch
http://www.ws6project.com/user_stor/...window-switch/
LNC 2000
http://www.nitrousoutlet.com/electro...ontroller.html
I also have a used timing tuner I am not going to run now in favor of a custom unit if you just want to replace what you have pm me if your interested in that.
