How much timing should I be running
Old Jul 5, 2004 | 07:29 AM
offaxis's Avatar
Default How much timing should I be running
hey guys
I just picked up a nx wet kit and I plan on running a 125 shot.
My question is what should I have the timing set at?
What do you guys run your timing at?
Thanks
Old Jul 5, 2004 | 10:30 AM
Ed Blown Vert's Avatar
I was running 25* on my 150 shot. It all depends if you have KR.
Old Jul 5, 2004 | 05:11 PM
Draco's Avatar
I run 22-23* with my 175 shot and am still getting some KR in the summer heat even with 94 octane. Might try a slightly colder plug and see if that helps.
For a 125 shot, I would run 25-26* of timing, but you should still be safe with whatever your stock timing is set to. Running lean is usually a bigger concern.
