fuel pump for 150 shot
Old Jul 6, 2004 | 05:02 PM
slik98z's Avatar
Default fuel pump for 150 shot
which inline or in tank or both? 255 is adequate?
Old Jul 6, 2004 | 05:29 PM
Gimp98TNT's Avatar
I used thr racetronix Plug and play kit it uses the 255 it believe. With a voltage booster it was good up too a 200 shot on a cam only car.
I would buy the racetronix again, very nice kit. BTW its a intank
Old Jul 6, 2004 | 06:44 PM
GM Muscle's Avatar
I'm using a the Walbro intake too. I havn't done a voltage blaster or hot wire kit and the fuel pressure still stays above 55psi when spraying.
Old Jul 7, 2004 | 02:08 AM
slik98z's Avatar
how difficult is it to install the in tank fuel pump? any modifications necessary to do this? i wanna run a 150-175 wet shot on a mostly stock set up (after a na /n2o tune of course).
Im at 341 right now with my mods. hopint for around 350-355 with the tune. with a 150 wet shot am i really going to make 150 rwhp? cause that would put me in the 500 area...which kind of freaks me out but would be so ******* awesome. i highly doubt it for some reason but it would be a definate pleasant suprise
Old Jul 7, 2004 | 02:56 AM
Z28Venom's Avatar
Walbro Install
Walbro Install 2
You don't have to settle for the 255 even though it'll be more than enough. Check with Nitro Dave, I'm sure that he can hook you up with a Walbro 340 for a great price. give him a call..
Old Jul 7, 2004 | 12:32 PM
slik98z's Avatar
Im thinking a 255 lph fuel pump would suffice. Would there be any issues with going with a larger fuel pump? Or would the car and nitrous fuel noid only pull what it needs?
