99 bird LS1
Old Sep 3, 2018 | 01:19 PM
qweedqwag's Avatar
Default 99 bird LS1
I want to use a Winmax window switch with rpm and tps, I am looking for a way to tap into the tach signal with hacking the harness all to hell, anyone have any experience tapping the signal. The manual for the window switch says tap into the green wire on the passenger side coil connector, looks tight.
Thanks,
Mike.
Old Sep 3, 2018 | 02:43 PM
Jtm2085's Avatar
I have always used the tach wire on the pcm
Old Sep 8, 2018 | 09:30 AM
qweedqwag's Avatar
How did you tap into it?
Thanks.
Old Sep 8, 2018 | 10:17 AM
Jtm2085's Avatar
I can't remember which wire it is. Google ls1 pcm pin out and it will tell you which wire is for the tach. I just used a wire tap
Old Sep 9, 2018 | 09:22 PM
qweedqwag's Avatar
thanks, i found the wire in the pcm bundle.
