Question about disabling launch controller on M6 car when spraying nitrous?
Just bought a full kit from Nitrous Outlet & have had an LNC2000 on the car for a while. Now the clutch switch activates it but I'll have to change that. Whats the easiest way to do it? 2000 Camaro SS M6
Don't know about your controller, however the LNC box has a 12v output wire that can be used to deactivate a nitrous stage...most controllers offer similar options. For example, (I do not remember the colors off the top of my head so I am making these up) the yellow 12v output wire on LNC is connected to the brown wire on my NX Max4 controller... In the settings for my 1st stage the max 4 will deactivate nitrous when it sees the 12v signal on that wire. Hopefully this helps you a bit.
The promax has a built-in interrupt. All you have to do is, off your clutch switch, bring 12v+ to the transbrake interrupt wire and then "enable" the trans brake interrupt in your settings. This will disable the nitrous while the clutch is depressed. Give me a shout if you have any other questions!
