Winmax Window switch
Old Sep 12, 2018 | 10:20 PM
qweedqwag's Avatar
Default Winmax Window switch
Anyone used a winmax on a 99-02 ls1 car?
Old Sep 13, 2018 | 08:34 AM
brandon@nitrousoutlet's Avatar
I have. What can I help you with?
Old Sep 13, 2018 | 12:00 PM
qweedqwag's Avatar
Default Winmax on 99 LS1 Firebird
Hey Brandon,
Can I use pin 10 (white wire) off the ECU for rpm signal on the winmax?
Thanks.
Mike.
Old Sep 13, 2018 | 12:39 PM
I haven't hooked one up there, but yes that is a tach signal wire.
Old Sep 13, 2018 | 02:10 PM
qweedqwag's Avatar
Did you use the coil wire? Top row second from the left?
Old Sep 13, 2018 | 02:28 PM
Yes sir. That's the one I always go to.
Old Sep 14, 2018 | 11:35 AM
qweedqwag's Avatar
HTF do you tap into that wire? It's so short.? I refuse to use a scotch lock.
