WOT/TPS Switch Tap in
Old Feb 26, 2019 | 04:36 PM
micbegz28's Avatar
Default WOT/TPS Switch Tap in
Hey Guys,
Currently trying to set up my Nitrous Express WOT/TPS window switch and just want to double check before i make any mistakes. Heres the diagram for the switch...
White Wire
it says either WOT switch, or + output from TPS. I should be able to use a T tap into the TPS harness, no biggie. but im a bit thrown off by the "+ output from TPS" I would assume that means positive output. Which would be pin 8, gray wire out of the PCM. But since it has to read throttle position, shouldn't i want it tapped into signal wire from the TPS? (dark blue, PCM pin 24)
Grey Wire
RPM signal, so just run a T tap into pin 10 off the PCM ?
