Nitrous lean
Old Jun 30, 2019 | 08:04 PM
fastlt1's Avatar
Default Nitrous lean
This weekend at the dragstrip. My wideband was being retarded again. Anyways. Spraying a wet kit. During run injector duty cycle 66 percent and 02s was around 700. Two questions.
1. If the car was lean would the injector duty cycle try max out to compensate?
2. Can you tell by O2 voltage what the AFR is?
Old Jun 30, 2019 | 08:39 PM
onebadbowtie86's Avatar
At 700 mv my car is at 13:1 for what its worth, 920-930 mv is 12.5:1. Your 02's are not controlling fueling at wot, thats whee you need to dial in your power enrichment, your injector duty cycle will not do anything to compensate on its own.
