Nos part# 05168NOS kit questions
Old Aug 30, 2019 | 08:46 PM
Taylor Pearson's Avatar
Default Nos part# 05168NOS kit questions
I bought this knowing that the kit was from a good brand. Looking back I wish I had went with someone else because of lack of info on this kit. I have read through the instructions and see no window switch or purge on it. I’m new to nitrous and have done a lot of reading and want to get the best hit on the track I can get. I have a stock LS1 in a 98 Camaro z28. I am going to get an independent fuel tank to supply the shot and gauges for fuel Pressure and tank pressure. What would you guys recommend to go with this kit. I want to go up in shot size eventually with plans on a forged rotating assembly. I’m sorry if I’ve left some info out just need some guidance from the nitrous gods! Thank you
P.S.: car is a 6 speed with 149,000 miles
Old Oct 9, 2019 | 05:43 PM
Spray n Pray's Avatar
I'm running a nos mini 2 stage controller for my nitrous setup along with the LNC 2000 box. The controller is pretty cheap and has an integrated window switch. I have it wired to pull timing with the LNC box when my nitrous is armed and my tps is at 100%. You can control quite a bit with the little thing. A purge isn't super necessary, but it helps. I was running a 125 shot with no purge before this setup, with no window switch(just off a button, was pretty ghetto, but it worked) It all comes down to how much you really want to spend. Depending on what shot you want to spray, you should have some way to pull timing for it. Get a step or two colder spark plug aswell. Good luck!
Old Oct 10, 2019 | 08:25 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
That kit doesn't include a window switch or purge kit.
You'll want to add one. As mentioned, something like the mini progressive controller has a built in window switch and allws for programming the power delivery, which is a huge benefit in any type of street car.
