This has turned into a big argument over the years on nitrous afr vs timing logic... Years ago the thing to do was rich and retarded, and guys would try to get away with being greedy on timing and bringing more back in, while leaving it fat. This is a good way to lift a ring. What a lot of big name nitrous guys have found over the past probably 10-15 years, is that you can run the car slightly leaner, say a few points richer than motor afr, but with plenty of timing taken out.. So basically in your case, say your car on motor is 28 degrees, at 12.5 afr WOT.... You may find it actually runs faster/cleaner, with 4 degrees out and a low 12/high 11 afr, than you would with the afr deeper into the 11s with the same timing out of it and the plugs will still show being safe.
Summed up, don't worry about having too much timing taken out. Just make sure it is not too fat and the motor will be just fine and run great.
